  1. Member pyrate83's Avatar
    Alive on XBOX LIVE!!!!!!!
    Ok, I used DVD decryptor to rip Jurassic park to my HDD. I have these files now but don't know what the next step is in order to get them burned to DVD. I also tried to rip and backup Signs, but haven't had much luck, even with DVDXCopy XPRESS. Any suggestions on what to do next with Jurassic park and how I might get Signs ripped to my HDD???
  2. Member pyrate83's Avatar
    Ok, thanks poopy. I think I will use an RW first just b/c this is the first time I will have used this method.
    Thanks again!
  3. Member pyrate83's Avatar
    Ok, well there is a chance I may have done something wrong here. I tried using DVD2one but it said it wouldn't do more than 30min since it's a trial version. Now, I also tried to use dvdshrink to access the files i got from decryptor but it turns out there aren't any ifo files...only vob files. What do I do now in order to get this movie onto a DVD????
    Need more advice plz.
  4. in DVDdecryptor->edit->select all files
    then rip
  5. Member pyrate83's Avatar
    So I gotta re-rip the entire movie again??????
  6. Member pyrate83's Avatar
    There has got to be a way for me to burn the files I already created in Decryptor....I hope.
    Would like to avoid ripping it again.
    Apr 2002
    The State of Frustration
    If you have Nero and the movie will burn to one disk, take all the files you ripped and burn to a disk.
    Hello.
