i'm kind of new to this. What is the best dvd burn on the market now? and what software is best for making dvd back up?
Thank you all in advance
Results 1 to 11 of 11
1: NEC ND-1300a, dual format DVD burner $145 here http://avlogic.com/product.cgi?code=18030059
2: DVDshrink (free), DVD2one, or DVDx Xpress. Oh and InstantCopy.
Actually a good deal IMO is to go tto www.321studios.com where if you buy DVDx Xpress (around $50) they are offering a dual format DVD+/-R/RW drive for $100. -
Originally Posted by taydu
Originally Posted by Bob W
even 8 MB buffers can't prevent buffer underruns -
I think all drives these days have some type of burn proof technology built in.
one more question then i might be out of you guy hair
. Is there a test burn option which let the buner pre-burn before it actually burn the data on the disc (if it ok then it will continue with the process, if not it would promt you to fix it and suggest that you not to burn it.) That would help in case of a small scratch on the original dvd .
what is the minimum requirement for the drive you show on top?
My system is old
466 intel celeron
256 mb ram
16x dvd-rom
dual hard dirve 20gigs + 120gigs
and Windows 2000 Pro
can it work on my system ok? Or I need a better system? -
DVD5 maybe, but certainly not DVD9. No red laser DVD burner to date can burn to DVD9 blank discs. In fact, no writable DVD9 disc exists as DVD9 disc is pressed and not burned.
Suggestion needed from DVD to HD
By onlygk in forum Newbie / General discussionsReplies: 4Last Post: 20th Nov 2010, 05:44 -
Suggestion for DVD to AVI / WMV
By CaseNote in forum DVD RippingReplies: 8Last Post: 8th Nov 2009, 23:53 -
Suggestion for DVD-R recorders
By dbldecue in forum DVD & Blu-ray RecordersReplies: 5Last Post: 27th Oct 2008, 20:08 -
DVD Recorder Suggestion
By mis3 in forum DVD & Blu-ray RecordersReplies: 9Last Post: 10th Feb 2008, 13:04 -
Need DVD Recorder Suggestion
By Mr. Burn in forum DVD & Blu-ray RecordersReplies: 13Last Post: 28th May 2007, 10:57
