Is AC-3 sound required to be at a bitrate of 384 for DVD? I record audio at 48 Khz and 224 bitrate, converting to AC-3 at 384 seems a waste of bits. Does AC-3 have increased file overhead which justifies the additional bitrate? With the given source, would using 224 result in any significant loss in audio quality? My current speaker system is not exactly hi-budget, but I hope to have better equipment in the future which might make any loss more obvious.
Most commercially made studio grade DVD discs use 192kbps for 2.0 AC-3 audio tracks. From what I've read you really only need a higher bitrate when you have something more than a 2.0 source such as a 5.1 source which needs a higher bitrate since there is more information. Most commercially made studio grade DVD discs seem to use 448kbps for 5.1 AC-3 but I've seen some use 384kbps as well.
Please note that the PANASONIC line of stand alone DVD recorders record to a 2.0 AC-3 with a bitrate of 256kbps
Perhaps the extra bitrate is needed since the encoding is being done on the fly?
I have seen a few commercial DVD discs use 224 or 256 but almost ALL use 192 for 2.0 AC-3 audio streams.
- John "FulciLives" Coleman
P.S.
I watch a lot of strange "older" movies that were originally made in mono or stereo at best (but not surround) so I see many 192kbps 2.0 AC-3 audio streams with the FULL SOUNDTRACK not just AUDIO COMMENTARY tracks (which also tend to be 192kbps 2.0 AC-3 streams)."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Excellent, thanks, guys. I am indeed doing 2.0 AC-3 from a captured Prologic input, but hope soon to be able to either cap or re-encode to true 5.1. Will go with 192 for now, or thereabouts.
Be careful using 192 kbps. I used it for some DVDs, and in certain players (PS2 and WinDVD w/ my PC player), when I'd use scene selection or fast forward in a scene, I would lose ALL audio. I re-did the same exact DVD w/ 224 kbps, and everything worked perfectly. Just a heads up.
I think it's fine... 128 = around 192 mp3 I think.... 192 would be around 224 mp3 so the quality is still great!
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 15:01 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 20:43 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 7th Nov 2008, 23:54
