  1. I ripped the subtitles with subRip and converted them to I-Author format.
    I tried to multiplex the video, audio & subtitles using the I-Author multiplexor. When it reaches the subtitles part the application terminates with a General Exception Error.
    Muxing without the subtitles works fine.
    So there must be something wrong with my subtitles ASCII file. I followed the only guide I could find on the net.
    Is there someone who has already done this?
    Any examples on how the ASCII file should look like?
    Feb 2001
    Berlin, Germany
    Actually you should have a *.txt file, that refers to *.bmp subtitles.
    In Subrip, did you save SubPictures as BMP?
    http://www.doom9.org/mpg/subs_and_multiple_audio_tracks.htm
    <font size=-1>[ This Message was edited by: Truman on 2001-10-01 05:08:30 ]</font>
  3. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    I think is a crack problem...
    Btw, multiplex without audio, then when the process is Ok, add the audio and remultiplex. It should go.
    If after 2/3 times, you still can't, delete everything about the subs, and rip them another time, and retry the whole procedure (no audio/audio), it should work.
    It's magic. No rational explain...^__^ (I tried on my own)
    Bye,
    MarioB79
  4. Member adam's Avatar
    Sep 2000
    Make sure you dont have any of your streams, audio, video, or subs, in folders with long path names. I-Author has a bug about that.
    So instead of c:\dvdrip\movie1\cd1\
    just do c:\cd1
  5. I tried again taking all the info into account.
    And... it works!!
    Thanks to all for the helping hand!!!
