Anyone having this problem?
I'm trying to burn a VCD using VCD Easy with chapters. On playback using my dvd player it always loop back to chapter two at the end of the movie. I've check carefully the interactivity feature when authoring using VCD Easy but still having the same problem.
This can only really be a interactivity problem, you need to select each chapter and make sure its correct.
It sounds like on the LAST chapter you have selected 'on timeout goto CHAPTER 2' you need 2 correct this to go to the chapter/menu etc that you want.
It should have on the last chapter 'on timeout goto ..pg u want..'
That should sort out the problem, i suggest u double check and make 100% sure. -
I've double and triple checked the last chapter which currently is set at VideoCD end, it is still looping back to chapter 2. One other thing I noticed as well, if I'm on a chapter after number 2 and hit the next key on the remote it also goes to chapter 2. Any other suggestion?
There is something undoubtedly wrong with the way you are authoring the disc.
I suggest reading the following: http://www.michaeltam.com/chapters.html
If you still can't fix it, I suggest that you post the XML on the forums and I can have a look.
Regards.Michael Tam
w: Morsels of Evidence -
The xml log file, thanks.
<?xml version="1.0" ?>
<!DOCTYPE videocd (View Source for full doctype...)>
- <!-- Made with VCDEasy v1.1.5.2 - http://www.vcdeasy.org
- <!-- See http://www.vcdimager.org/guides/general_xml_structure.html to have details
- <videocd xmlns="http://www.gnu.org/software/vcdimager/1.0/" class="vcd" version="2.0">
<option name="relaxed aps" value="false" />
- <info>
<album-id />
<volume-count>1</volume-count>
<volume-number>1</volume-number>
<restriction>0</restriction>
</info>
- <pvd>
<volume-id>EPISODE_11</volume-id>
<system-id>CD-RTOS CD-BRIDGE</system-id>
<application-id>CDI/CDI_VCD.APP;1</application-id>
<preparer-id />
<publisher-id>VCDEASY_V1152</publisher-id>
</pvd>
- <filesystem>
- <folder>
<name>SEGMENT</name>
</folder>
</filesystem>
- <sequence-items>
- <sequence-item src="F:\ep11\ep11-mul.mpg" id="Sequence-0001-01">
<default-entry id="Chapter-0001-01" />
<entry id="Chapter-0001-02">504.087</entry>
<entry id="Chapter-0001-03">1008.958</entry>
<entry id="Chapter-0001-04">1513.379</entry>
<entry id="Chapter-0001-05">2017.682</entry>
<entry id="Chapter-0001-06">2521.219</entry>
</sequence-item>
</sequence-items>
- <pbc>
- <selection id="Selection-000" rejected="false">
- <!-- Sequence-0001-01 - 0:00:00.000 - ep11-mul.mpg
<bsn>1</bsn>
<next ref="Selection-001" />
- <!-- Key Next: Chapter-0001-02 - 0:08:24.087 - ep11-mul.mpg
<timeout ref="Selection-001" />
- <!-- On Timeout: Chapter-0001-02 - 0:08:24.087 - ep11-mul.mpg
<wait>0</wait>
<loop jump-timing="immediate">1</loop>
<play-item ref="Sequence-0001-01" />
- <!-- Item to Play: Sequence-0001-01 - 0:00:00.000 - ep11-mul.mpg
<select ref="Selection-000" />
- <!-- Key 1: Sequence-0001-01 - 0:00:00.000 - ep11-mul.mpg
<select ref="Selection-001" />
- <!-- Key 2: Chapter-0001-02 - 0:08:24.087 - ep11-mul.mpg
<select ref="Selection-002" />
- <!-- Key 3: Chapter-0001-03 - 0:16:48.958 - ep11-mul.mpg
<select ref="Selection-003" />
- <!-- Key 4: Chapter-0001-04 - 0:25:13.379 - ep11-mul.mpg
<select ref="Selection-004" />
- <!-- Key 5: Chapter-0001-05 - 0:33:37.682 - ep11-mul.mpg
<select ref="Selection-005" />
- <!-- Key 6: Chapter-0001-06 - 0:42:01.219 - ep11-mul.mpg
</selection>
- <selection id="Selection-001" rejected="false">
- <!-- Chapter-0001-02 - 0:08:24.087 - ep11-mul.mpg
<bsn>1</bsn>
<prev ref="Selection-000" />
- <!-- Key Prev: Sequence-0001-01 - 0:00:00.000 - ep11-mul.mpg
<next ref="Selection-002" />
- <!-- Key Next: Chapter-0001-03 - 0:16:48.958 - ep11-mul.mpg
<timeout ref="Selection-002" />
- <!-- On Timeout: Chapter-0001-03 - 0:16:48.958 - ep11-mul.mpg
<wait>0</wait>
<play-item ref="Chapter-0001-02" />
- <!-- Item to Play: Chapter-0001-02 - 0:08:24.087 - ep11-mul.mpg
</selection>
- <selection id="Selection-002" rejected="false">
- <!-- Chapter-0001-03 - 0:16:48.958 - ep11-mul.mpg
<bsn>1</bsn>
<prev ref="Selection-001" />
- <!-- Key Prev: Chapter-0001-02 - 0:08:24.087 - ep11-mul.mpg
<next ref="Selection-003" />
- <!-- Key Next: Chapter-0001-04 - 0:25:13.379 - ep11-mul.mpg
<timeout ref="Selection-003" />
- <!-- On Timeout: Chapter-0001-04 - 0:25:13.379 - ep11-mul.mpg
<wait>0</wait>
<play-item ref="Chapter-0001-03" />
- <!-- Item to Play: Chapter-0001-03 - 0:16:48.958 - ep11-mul.mpg
</selection>
- <selection id="Selection-003" rejected="false">
- <!-- Chapter-0001-04 - 0:25:13.379 - ep11-mul.mpg
<bsn>1</bsn>
<prev ref="Selection-002" />
- <!-- Key Prev: Chapter-0001-03 - 0:16:48.958 - ep11-mul.mpg
<next ref="Selection-004" />
- <!-- Key Next: Chapter-0001-05 - 0:33:37.682 - ep11-mul.mpg
<timeout ref="Selection-004" />
- <!-- On Timeout: Chapter-0001-05 - 0:33:37.682 - ep11-mul.mpg
<wait>0</wait>
<play-item ref="Chapter-0001-04" />
- <!-- Item to Play: Chapter-0001-04 - 0:25:13.379 - ep11-mul.mpg
</selection>
- <selection id="Selection-004" rejected="false">
- <!-- Chapter-0001-05 - 0:33:37.682 - ep11-mul.mpg
<bsn>1</bsn>
<prev ref="Selection-003" />
- <!-- Key Prev: Chapter-0001-04 - 0:25:13.379 - ep11-mul.mpg
<next ref="Selection-005" />
- <!-- Key Next: Chapter-0001-06 - 0:42:01.219 - ep11-mul.mpg
<timeout ref="Selection-005" />
- <!-- On Timeout: Chapter-0001-06 - 0:42:01.219 - ep11-mul.mpg
<wait>0</wait>
<play-item ref="Chapter-0001-05" />
- <!-- Item to Play: Chapter-0001-05 - 0:33:37.682 - ep11-mul.mpg
</selection>
- <selection id="Selection-005" rejected="false">
- <!-- Chapter-0001-06 - 0:42:01.219 - ep11-mul.mpg
<bsn>1</bsn>
<prev ref="Selection-004" />
- <!-- Key Prev: Chapter-0001-05 - 0:33:37.682 - ep11-mul.mpg
<timeout ref="Selection-end" />
- <!-- On Timeout: VideoCD END
<wait>0</wait>
<play-item ref="Chapter-0001-06" />
- <!-- Item to Play: Chapter-0001-06 - 0:42:01.219 - ep11-mul.mpg
</selection>
<endlist id="Selection-end" rejected="true" />
</pbc>
</videocd> -
As you can see, the timeout for each of your <selection> (which incorporates each chapter) timeouts to the NEXT chapter. That is, when the whole film finishes playing, it timeouts (that is, goes to automatically) to chapter 2.
You should set the timeout ref as an endlist or to some main menu or something.
Regards.Michael Tam
It worked !!!! Interesting though only "selection-000" that corresponds
to "Sequence-0001-01" needs to be set to VCD end on time out, the rest of the selections corresponding to the chapters can be left to advance to the next chapter. Thinking about it and looking at the code this makes sense but from the VCD Easy UI perspective, it is a little confusing.
Thank you very much.
AVStoDVD Chapter Problem
By adyf in forum Authoring (DVD)Replies: 11Last Post: 21st Dec 2010, 14:03 -
mkv chapter file problem
By Bully9 in forum EditingReplies: 12Last Post: 22nd Mar 2010, 18:06 -
Muxman problem with chapter times
By lordretsudo in forum Authoring (DVD)Replies: 12Last Post: 9th Jan 2010, 07:52 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
VCD Easy
By kshavo in forum Authoring (VCD/SVCD)Replies: 10Last Post: 12th Feb 2008, 14:43
