If anyone can you give me any foreseeable problem with this capture card Kworld V-Gear DV/AV Video Capture MPEG Record Card.
V-Gear DV Pro is a specially designed DV/Analog video editing system for camcorder hobbyists. With its integrated high-speed IEEE1394/i.Link DV interface and Analog video (Composite & S-Video) inputs, V-Gear DV Pro lets you capture any video whether from V8, Hi8, D8, DV or VHS into MPEG files, in real-time.
V-Gear DV Pro delivers all magic tools you need to turn raw footage into fantastic videos. Capture video in small and long-lasting MPEG files ith the built-in DV/Analog input connectors to save your hard-drive space and let PowerDirector Pro DE, the new "0" rendering MPEG editing software produce a fascinating movie instantly. Our exclusively 3D CG library, 3DBANK CG PAK, can add strong visual impact on your video, in addition to fully professional video editing features, custom sound features, let you sync your audio perfectly and add incredible sound effects in minutes. Finally, with the included DVD burning software, your masterpiece can be put into VCD, SVCD, mini-DVD or DVD for permanent storage.
From video capture and editing all the way through to burning a disc to play on your set top DVD player, V-Gear DV Pro makes it easy and fun to make great home movies. The complete compatibility and versatile entertainment of V-Gear DV Pro really provide an ideal video editing solution.
DV/Analog Compatible, Capture All The Wonders!
V-Gear DV Pro - Digital/Analog compatible video editing system, integrates high-speed IEEE1394/i.Link DV interface and Analog video (Composite & S-Video) inputs which lets you connect analog VCR plus DV/Digital 8 camcorder to PC and capture any video into MPEG files, in real-time. The complete compatibility and versatile entertainment of V-Gear DV Pro really provides an ideal video editing solution.
"0" Rendering MPEG Video Editing, Fast And Easy.
Included PowerDirector Pro DE comes complete with an advanced, yet easy-to-use video editing interface that lets you create dazzling video productions. There are many more powerful functions! Automatic Scene Detection shortens the time you spend on video editing; splendid effects, subtitles and transitions can be used to create a fabulous homemade Hollywood-style movie. Even better, with its exclusive SVRT (Smart Video Rendering Technology), you won't spend time on recompression of files, and you'll be able to export instantly in VCD, SVCD and DVD formats. You can also record your works to DV tapes with its built-in DV output connector.
DVD Made Easy.
Beyond video editing, PowerDirector Pro DE is also a complete solution to creating movies on CDs and DVDs. It provides authoring and burning tools of VCD, SVCD, mini-DVD and DVD, all 100% integrated. The step-by-step Disc Making Wizard will guide you through arranging video clips, backgrounds, menus, chapters, interactive buttons and slide shows. You can also apply various templates and use the Preview Mode to easily check if everything is right for you, and then push the burning button to make DVD or mini-DVD. It's that simple.
Royalty-free 3DBANK CG PAK SE - Smart CG Library, Enrich Your Video Instantly.
3DBANK CG PAK is a specially designed CG library for digital video! All CG and animations in CG PAK are produced by professional 3D technology, providing supreme broadcast D1 quality and including all CG types needed in video editing, such as full screen cards, subtitles, frames and animations. You can superimpose CG onto your video immediately, and add a strong visual impact on your video.
SmartSound - Create Soul-Stirring Music In A Wink!
V-Gear DV Pro includes an easy-to-use audio software, SmartSound, a background music generator that creates perfect soundtracks matched to the movie, instantly. Simply select music tones, from Classic to Rock'n'Roll. You can create soul-stirring background music in minutes instead of hours. Easy, quick, precise and royalty-free!
Plug-and-play 32 Bit PCI interface
Capture video source from - VHS, V8, Hi8, DV, D8.etc
New WDM capture driver support
Standard OHCI - DV/Digital 8 interface
Compatible with DV/Digital 8 camcorder equipped with "FireWire", "i.Link", or "IEEE1394" connector
Resolution:
- NTSC: 80 x 60 to 720 x 480, 30Frame/Second*
- PAL/SECAM: 80 x 60 to 720 x 576, 25Frame/Second*
Video adjustment
Hue, Brightness, Contrast and Saturation
Video connectors:
IEEE 1394/i.Link Input/output(4pin), Composite(RCA) input and S-Video input
Audio connectors:
Phone jack (3.5mm/stereo) input/output
DV Format:
NTSC: 720 x 480(CCIR601), YUV 4:1:1, 30fps, 5:1 DV CODEC, 3.6MB/sec
PAL/SECAM: 720 x 576(CCIR601), YUV 4:2:0, 25fps, 5:1 DV CODEC, 3.6MB/sec
I have one of these. I have never been able to produce a quality capture from VHS. Using the same hardware and an ATI AIW 8500 DV, my captures are fine.
The problem I had is that the video produced would start to lose sync partway into the film and continue to degrade from there.
I wish I knew more, but I did not have an enjoyable experience with this card.When life gives you lemons, throw them at the happy, shiny people.
Episode Information
By Deeman69 in forum Newbie / General discussionsReplies: 1Last Post: 24th Jan 2012, 15:58 -
US Video CD information?
By phatrat1982 in forum Newbie / General discussionsReplies: 5Last Post: 13th Jun 2011, 23:07 -
h264 information?
By orangeboy70 in forum Newbie / General discussionsReplies: 0Last Post: 26th Mar 2011, 19:04 -
system information
By deadman1972 in forum Newbie / General discussionsReplies: 4Last Post: 15th May 2008, 10:03 -
File information
By TyWelcome in forum Newbie / General discussionsReplies: 1Last Post: 9th Dec 2007, 14:52
