Hi ev'body!
Here's my newbie question:
I am looking for a detailed comparison on the various formats and their advantages, e.g. what format is (in terms of quality) the best?
I have problems in interpreting the ffmpegX manual and its descriptions of the different formats correctly, for me they are quite vague...
Any help (links tips etc.) is deeply welcomed!
ISSI
Okay, I should have told you: the target is TV.Originally Posted by major
I am not sure if XVID is better or mencoder mpeg-4...
Is there any place to find further info on this toppic? (Another question is: Does it make sense to scale a DVD source to a DVIX movie with more than 720 pixels, let's say 800 or even more?)
Thanks for any help!
I am so sorry: I made a mistake! I wanted to say:Originally Posted by major
The target is computer. And I want to store on CD-R.
Is there any place (a www-link maybe) to find further info on this toppic?
Thanks for any help! (...and sorry for the confusion...)
Choose XviD for quick quality encode, or for even better quality you should use mencoder mpeg-4 with all advanced options enabled, though this will be extremely slow to encode.Originally Posted by ISSI
For computer playback it does not make any sense to scale to a size bigger than the source size.Originally Posted by ISSI
@ Major: Thank you for your kind help!
Really? What about "Use B-frames"? I thought, (because the ffmpegX OPTION description says "B-frames require less data than P-frames") that B-frames are likely to reduce size, but not improve quality... so, am I wrong with this?Originally Posted by major
Even with a screen bigger than 720 pixels width? Ain't it better to let the encoder do the upscale, and not the viewing program?Originally Posted by major
Bye!
ISSI
The main advantage of B-frames is reducing the encoded file size. However they can also improve quality in the case of moving objects that reveal hidden areas, as they use backward prediction.Originally Posted by ISSI
No. You're going to waste disk space with redundant data, and to waste processor power to decompress such redundant data.Originally Posted by ISSI
dvix/xvid to dvd using ffmpegx???
By Jgarlich in forum ffmpegX general discussionReplies: 2Last Post: 20th Jul 2009, 21:57 -
A DVD recorder with a USB Direct connection that allows Dvix and Xvid
By Conercao in forum DVD & Blu-ray RecordersReplies: 9Last Post: 6th Dec 2008, 13:22 -
DVD shrink vs DVIX video quality
By sportflyer in forum Newbie / General discussionsReplies: 3Last Post: 2nd Sep 2008, 21:31 -
Sound Problem During Playback (XVid, DVIX etc.)
By Pyrolisk in forum Newbie / General discussionsReplies: 5Last Post: 21st May 2008, 12:00 -
avi dvix, mpeg quicktime dvd quality question
By minmin2003 in forum Newbie / General discussionsReplies: 2Last Post: 26th Aug 2007, 13:16
