Hi,
I noticed a few discs I have recently burned (Optodisc gold tops) have some skipping withing the movie. Can I copy the the media that is skipping onto my hard drive and then reburn onto better media or do I have to start from scratch and encode/reauthor from the original?
I'm not sure if the skipping will be someow copied if I rip the movie from the bad media onto my hard drive.
Results 1 to 9 of 9
that's a good question, and the answer unfortunately, is "usually" not.
The reason for this is because the data is damaged on that part of the disk due to bad sectors.
Sometimes cheap quality media will cause skipping on some standalone players, but will not on others. Also, in those particular cases, the media will be able to be read by a DVD-ROM. If that is the case, then you should have no problem re-ripping the data off the disk.
However, in most cases, your DVD ROM won't be able to play those disks in the damaged spots..and as a result...you are SOL A.K.A Shit out of Luck. Try to put one of the disks in question and play it with your DVD ROM...if it locks up at the same point as your standalone....go ahead and try to rip the disk...but you aren't going to be able to. -
Maybe maybe not, why not just try it? If you don't get copy errors you are good to go....
Now that they know the answer...maybe they'll research what types of media they should be purchasing. At least that's what I would do if I were in their situation. -
good media is always better
as the slogan goes "good media is never cheap and cheap media is never good" -
Try it on your PC. If it plays on the PC with no skipping, great. If not, rip it to your hard disk. If it plays THERE with no skipping, then reburn it.
If you can't rip it (bad sectors, etc.) then sorry.
- Gurm
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
Bad DVR-MS files with Vista Media Center
By waxtadpole in forum Media Center PC / MediaCentersReplies: 6Last Post: 13th Dec 2008, 16:50 -
Blu-Ray Media - Who's good and Who's bad.
By SCDVD in forum MediaReplies: 1Last Post: 23rd May 2008, 03:58 -
Bad DVD media
By PhoneMatt in forum Newbie / General discussionsReplies: 13Last Post: 19th Jan 2008, 11:01 -
video skips in media player classic.
By zzyzx2 in forum Software PlayingReplies: 6Last Post: 4th Oct 2007, 12:21
