  1. I have an PAL mpg movie that plays great in Windows Media Player but is not vcd compatible, so I loaded it into TMPGEnc to convert it, but it's showing that an over 1 hour video is less then 10 minutes long. For the heck of it, I went ahead & converted it & it only did the first 6 minutes & then it was finished.
    Any ideas?
  2. Try and get a program to rewrite the header for it. A remux program should be able to do this.
    My AVI -> Any Format Guide is available here.
    My Frame Resize Calculator (enhanced for Virtualdub) is available here
  3. I'm pretty new to this, can someone be a little more specific & point me to the correct program to accomplish this?
  4. Look in the tools here or google search it.
  5. When I look in the tools section & search remux or rewrite header, I get nothing.
    Can someone actually give me a program name please?
    From searching around some more on the forum, it looks like I should be able to do something with tmpgenc, which I already have.
    I found somewhere that you need to go to file, mpg tools, & there cut & merge.
    I loaded it into tmpgenc again to convert, it's now only a 23 min. movie.
    Can someone please give me a program name & the necessary steps please?
  6. Originally Posted by Donna Stefani
    With TMPGenc all you have to do use the not simple Demux and then Simple Mux. In the MPEG tools.
