First sorry if this has been covered!.Try using the search engine but its down at the moment...
Anyway does dvdlab have a problem with certain pioneer dvd player.
I have made a few dvd using dvdlab and all i have worked great on every dvd player apart from the pioneer 625 and 757.These players play the dvdlab authored discs but there is no sound!.
If anyone can help i would be most gratefull!
Steve
Are you using Dolby Digital or MPEG audio?
My Pioneer player was not producing sound on MPEG audio until I went into the setup menu and changed one of the options (can't remember which one exactly, but it was an obvious one!)
Nick -
Are you using BeSweet to convert wav to ac3? Some people say they have problems with Pioneer using ac3 converted with Beweet. I've never had problems, but I don't have a Pioneer.
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
i have had alot of problems with ac3 and pioneer. Some made with bsweet and some converted with DVDit.
no i am just adding menu and chapters to homemade dvds,made either on a standalone philips or Panasonic machine
Check that you are not using video clips with mixed audio formats, one video clip with MPEG2 audio and then another video clip with DD audio while authoring your DVD. My Panasonic DVD Video Recorder will only play the audo format of the first video played. So now I only make sure that I use one audio format throughout all video clips when i'm making my DVDs with mulitple video clips. Menu audio is not affected.
Cedocida - "Jittery" playback on some media players/DVD players
By BertRito in forum Newbie / General discussionsReplies: 11Last Post: 4th Aug 2010, 20:20 -
Music in your DVD Menu's with DvdLab Pro
By RickyPinxt in forum Authoring (DVD)Replies: 5Last Post: 8th Apr 2010, 18:45 -
Audio distortion (clipping) on computer drives/players but not dvd players
By Left/Right in forum AudioReplies: 2Last Post: 5th Nov 2008, 20:21 -
Pioneer Players wont play SVCD2DVD Creations...fix?
By alangriffin in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 2nd Jul 2008, 10:06 -
CC_Mux & Pioneer DVD Players
By Gypsy898 in forum SubtitleReplies: 4Last Post: 26th Apr 2008, 13:39
