I have a large MPEG file that i am trying to make a dvd or vcds. Is there a utility that will allow me to create multiple vcds or dvds from one single file?
ulead dvd movie factory will allow you to author via VCD or DVD, your choice. It will tell you the resulting file size, you can then use it to cut it to fit to your chosen format. For each additional disk just cut it at the previous disks stop point, ect....
@bugsbunny,
what type of "large MPEG file" you have???
you sure it's VCD MPEG-1...or could it be SVCD MPEG-2??? and is it standard, compliant???
IF YOU HAVE A STANDARD COMPLIANT VCD MPEG-1
to make VCD...
first split your large MPEG file into 795 MB segments using TMPGEnc: https://www.videohelp.com/tmpgencedit.htm
then, burn them to VCD using Nero: https://www.videohelp.com/nero.htm
to make DVD....
https://www.videohelp.com/vcddvdr.htm (you can directly author VCD MPEG-1 on a DVD and it should be fully standard, compliant DVD because VCD specs are accepted by DVD specs)
How do I create a DVD Menu
By RKM1552 in forum Authoring (DVD)Replies: 6Last Post: 23rd Feb 2010, 13:19 -
Create DVD with TMPGEnc DVD Author 3 and not read on DVD Player
By Salutatous in forum Authoring (DVD)Replies: 1Last Post: 22nd May 2008, 11:22 -
Final Cut Express 4 can I create chapters for a DVD I create
By Jabroni4872 in forum MacReplies: 1Last Post: 18th May 2008, 12:36 -
how to create VCD protection?
By C-W in forum Authoring (VCD/SVCD)Replies: 4Last Post: 18th May 2007, 13:00
