I am having a problem with a decrease in the playback volume when tranfering from DVD to VHS. I just use simple process no ripping encoding etc.... This does not occur on all transfers. At present first time this has happened. I could not determine which form to post this in. Is there anything That I can do, I have already cleaned the VHS heads, thinking maybe I need to have VHS serviced and cleaned professionally.
disconnect and reconnect your cables from the DVD to the VCR. And make sure it is not the disk, by using another disk.
Hello. -
Thank You for the suggestion, so far it is just that DVD, others seem to be louder in volume. I even exchanged the DVD re backed up with much the same results.
I will try your suggestion.
Generational Loss in a VHS -- What exactly is happening?
By hannpe01 in forum Newbie / General discussionsReplies: 1Last Post: 16th May 2010, 19:42 -
multiAVCHD - DVD to BDR - unexpected loss of audio quality
By HatchetMan in forum Video ConversionReplies: 5Last Post: 10th May 2010, 11:59 -
Burned a 2prt avi to dvd Loss of audio on 2nd part of the movie.
By Ryanmhindman in forum AudioReplies: 2Last Post: 22nd Sep 2009, 14:43 -
tranfering files from PC to PC?
By yogart in forum ComputerReplies: 16Last Post: 2nd Jun 2007, 14:46 -
Quality loss VHS > CVD, DVD
By rglmrj in forum Video ConversionReplies: 15Last Post: 1st Jun 2007, 12:13
