i want to frameserve a movie with subtitles and i want the sub to be on the black lines buttom...how can i do that?
is there anyother way to frameserve to CCE (including sub's) than Vdub?
The answer to first question is, yes. I always put subtitles on the bottom black bar. Here is what you need to do. You need DVD2AVI, VDub, Avisynth, VobSub.
I assume you are familiar with procedure of normal frameserving with DVD2AVI-->AVISynth-->Virtualdub. Now you need to rip subtitles from VOBs with VobSub. After that, load your AVIsynth script into VDub, then go to filters, choose VobSub, load your VobSub file. To place subtitles properly, choose Configure to adjust. When everything is in place, you can start frameserving to your encoder.
Answer to second question is also yes. In fact, unless necessary, you don't need VDub to frameserve. AVIsynth is much faster and versatile. But it doesn't have a GUI, so I use VDub to preview my script. -
VobSub is an external filter. You need to install it first. Link:
http://www.afterdawn.com/software/video_software/subtitle_tools/vobsub.cfm -
ok, but this filter can accept sub files ripped from a DVD and not a txt file or ssa file...i have converted it from ssa to sub but it wont load it...any ide?
You were on a roll until you spoke without realizing there are several GUIs for AviSynth. I was going to try all of them until I became addicted to AVSGEN.Originally Posted by PoplarHello.
Where can I download Frameserve ?
By DuBsTaR in forum Newbie / General discussionsReplies: 19Last Post: 9th Dec 2011, 19:47 -
Can't Frameserve to Tmpgenc
By BonnieW88 in forum Video ConversionReplies: 1Last Post: 31st Aug 2009, 00:40 -
Frameserve from virtualdub to HC
By SatStorm in forum Video ConversionReplies: 2Last Post: 12th Jun 2009, 07:24 -
Frameserve on MacOS??
By Maxwellbest in forum MacReplies: 5Last Post: 4th Oct 2008, 17:34 -
How do I DeInterlace and Frameserve?
By rocky12 in forum Newbie / General discussionsReplies: 0Last Post: 17th Jul 2008, 22:50
