  1. Either I am not looking in the right places, or i cannot seem to find this one.
    I have a DiVX 640x256 (2.50:1) [=5:2] with AC3 sound and .sub and .idx files all together.
    Now I want to convert to DVD MPEG, but keep the ratio, AC3 sound and I want to include the sub files on my final DVD. How to do this?
    If I missed a guide or something, please point me to it, if not, can anyone help me out here?
  2. Just about everything you need will be found here: https://www.videohelp.com/convert
    Remember, these guides are not perfect and often get out of date. Also they don't fit all situations. I suggest you read all applicable guides carefully and extract the various steps that suit your requirements, knowledge level and available tools.
  3. I have been reading about all available guides here and on Doom9, and have a relatively good knowledge about things, but this is the first time I will work with AC3 sound and original aspect ratio. For some reason, TMPGEnc wants to make a 4:3 file, whatever settings I use, so , like I said, I think I'm missing something...... Question remains, what am I missing and HOW do i do it?
  4. You will need DVDMaestro. I hope you have it since they don't sell it anymore. I don't know if DVDLab does subtitles. Anyway, use my guide to convert to a DVD compatible MPEG2, then load up MaestroSBT and load the .sub file and convert. Then, load the output into DVDMaestro.
    My AVI -> Any Format Guide is available here.
    My Frame Resize Calculator (enhanced for Virtualdub) is available here
  5. Originally Posted by NiGHTCReaTuRe
    The divx probably isn't a true 16:9
    What I would do is encode at 4:3 with boarders added.
  6. Originally Posted by thayne
    That's pretty stupid, although I'll let it slide this time since it looks as though you lack just a little experience, or you made an error carelessly. What you should REALLY do, since you're going to DVD, is encode to anamorphic 16:9 with the 5:2 letterboxed inside of it. My guide includes all this, so it shouldn't be a problem for you.
  7. Originally Posted by funkguy4
    Well, when it doesn't work he can try my way....
  8. Originally Posted by thayne
    Commercial DVDs come encoded this way........if it's (super)widescreen they don't go letterboxing it into a 4:3 frame. Then when you watch it on a widescreen TV it will look like TGPO.....
