Does anyone else here have problems with their Pioneer 105/A05 when using RecordNow Max 4.5??? It constantly gives me errors when burning with that program, but my TDK 440 has no problems whatsoever. But when burning with Nero 6.0, my 105 is fine and burns properly, it ALWAYS terminates with errors with RecordNow Max.
Does anyone know how to correct this?
If you are buring dvd movies with RecordNow Max it must be 100% DVD format structure. Meaning you have to have a empty AUDIO_TS folder and VIDEO_TS with correctly edited *.IFO files and needed *.BUP *.VOB and Default.pls files.
It will terminate immediatly if it isnt 100% correct to structure.
There is an option in RecordMax to turn off checking of DVD structure compliant files. But then they wouldnt play in a stand alone.
If that wasnt the problem, then its your media you are using. Try another brand pref. one made in Japan. -
But I am burning .iso or .img movies. They are just image files that should burn with no problem. Is there a setting for these also?
You are burning *.ISO and *.IMG files...
Dude.... use Alcohol 120%
it will work....er should work.
yea, I downloaded and installed the newest pxengine already....px408
I don't know what else it could possibly be. -
I don't know then.
How about RecordNow DX 4.6 (plus the pxEngine of course)
4.6 must be a little bit better than Max 4.5
What is max bitrate and max channels supported by PCM audio format?
By Bonie81 in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2010, 00:35 -
Pioneer 111D problems
By EGrier in forum DVD & Blu-ray WritersReplies: 12Last Post: 25th Oct 2008, 01:35 -
pioneer having problems with 112 drives
By aedipuss in forum DVD & Blu-ray WritersReplies: 2Last Post: 24th Dec 2007, 07:50 -
Illegal Disc Error w/Pioneer DVR-105 in Nero
By Quadzilla in forum DVD & Blu-ray WritersReplies: 2Last Post: 20th Aug 2007, 13:23 -
Pioneer 112D problems
By Xande in forum DVD & Blu-ray WritersReplies: 1Last Post: 28th May 2007, 22:13
