Are there any other capturing programs that can be used with Hauppauge WinTV PVR USB, than WinTV2000?
dcsos SCENALYZER for DV file not MPEG, sorry khilkemen there nothing eles how ever the newer WinTV-PVR2 USB will have some 3rdparty support.
I should know better...sorry..
and thanks...
because its a SOFTWARE MPEG--it needs the HAPPAUGE PROGRAM
is that the gist..
I know ULEAD HAS A MPEG CAPTURE PROGRAM..but I think these only work with the right hardware
have you tried? this will work
Snapstream Personal Video Station
http://www.snapstream.com/
probably doen't work any better -
It has hradware, not software encoding. Ulead won't work with. I don't know about the USB ver, but SageRecorder works well with the pvr-250 pci card.
AverTV USB HD DVR or Hauppauge USB HD PVR
By gll99 in forum Capturing and VCRReplies: 34Last Post: 8th Jun 2015, 09:56 -
[Sloved] Hauppauge WinTV PVR-150 capturing using off air cable plug
By Wizard23 in forum Capturing and VCRReplies: 4Last Post: 11th Feb 2011, 21:07 -
Hauppauge WinTV PVR 250
By kenmo in forum ComputerReplies: 10Last Post: 28th Apr 2009, 13:21 -
What software for capturing Hi-8 with Hauppauge WinTV 250 PVR USB2?
By boscabru in forum Capturing and VCRReplies: 10Last Post: 5th Mar 2008, 02:19 -
Considering Hauppauge WinTV PVR 350...
By chewie8008 in forum Capturing and VCRReplies: 9Last Post: 2nd Oct 2007, 17:20
