Sorry, I'm new to the world of capturing. I have a WinCast TV Hauppauge card and am using Virtual Dub to capture TV episodes from VHS tapes. Windows 2000, Pentium 4 system.
I would like to encode these at close to 320x240 in divx format. I followed the how-to guide and everything works fine... but the files are twice as big as I want them to be (even after compressing the audio). The 22-minute episodes are coming out at around 180 megs. I have many episodes that I've gotten from other people, and they are 320x240 in divx format and are around 60 to 90 megs. What can I do to get my captured files down to that size? Is there a compression setting I'm not using (I select "divx - low motion", like the guide suggests)?
Any help would be appreciated!
- Kelly
http://www.episodesoncd.com/
Select as usual divx low motion but click on configure, lower the data rate to about 430(default 910) and you will fit 22 min/90 MB. And use also a low bitrate/date rate for the audio like 128 kbit/s.
Freeware for compressing DVD files
By Ricky_E in forum DVD RippingReplies: 59Last Post: 3rd Aug 2010, 13:11 -
Compressing .vob or .ifo files using DVD Shrink
By hostofsorrow in forum Authoring (DVD)Replies: 4Last Post: 21st Jan 2010, 22:19 -
compressing avi files
By romanstopme in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2009, 20:36 -
Compressing ISO files for DVD?
By mr_goodbomb in forum Authoring (DVD)Replies: 2Last Post: 5th Jul 2008, 08:32 -
Compressing AVI Files to Burn to DVD?
By ryevick in forum Authoring (DVD)Replies: 17Last Post: 27th Nov 2007, 21:59
