What other software will let me capture at 720x480 besides Virtualdub, WinDVR and PowerVCR 2? I would really like to find something that is freeware or shareware. Any suggestions?
I could not get Virtualdub to do it. It would give me an error message when trying to capture at that particular resolution. Windvr 2 would not let me but Windvr 3 would. I only have the trial version of it and I don't want to spend $80 on it just for that feature.
Yes, I read it. I just got done capturing with it and it looks very good. I am losing frames once in a while though and the audio does not sound as good as I think it should. It is somewhat distorted. How can I fix the audio to sound better and are there any settings I should change to stop the frame dropping. I have a P4 2.53 with 128mb RAM.
are you using onboard sound? that can contribute to poor audio...i capture at 48khz stereo and it sounds fine....
you might be dropping frames cos you're not capping to a separate drive...check the sticky thread about why your system drops frames....the problems you are talking about has been covered extensively in this forum so try searching...you'll get tons of info
Capturing TV Broadcasting using ATI TV WONDER 650 PCI
By jluke in forum Capturing and VCRReplies: 3Last Post: 6th Nov 2009, 01:10 -
going CRAZY: capturing with ATI HD 3600 (analog)
By nuzumaki in forum Capturing and VCRReplies: 6Last Post: 13th Jan 2009, 18:24 -
ATI AIW 128 720x480 mpeg captures have horizontal tearing
By cybertheque in forum Capturing and VCRReplies: 16Last Post: 17th Sep 2008, 21:53 -
ATI ALL in WONDER 9600 TV & capturing problem
By ikeogut in forum Capturing and VCRReplies: 35Last Post: 31st Aug 2008, 05:51 -
Why DVD (720x480) bigger than AVI(720x480)
By psxiso in forum Video ConversionReplies: 6Last Post: 3rd Feb 2008, 06:50
