When I scan MPG's using DVDPatcher, I often find that the specified bitrate is *way* higher than the actual bitrate, and many times the aspect ratio is something nonsensible (like "|12"). This especially seems to be the case with MPEG1. Yet I've never found this to affect playback in any way.
Why is bitrate specified, then? Do any software or hardware players actually use this information in any way?
With VBR they report the MAX rate. The average rate
is not knowable without scanning the entire video.
3 Videos Mostly Vary in Bitrate...how important is it?
By justravis in forum Newbie / General discussionsReplies: 2Last Post: 25th Feb 2011, 04:16 -
Problem with missing headers
By twentworth in forum DVD RippingReplies: 8Last Post: 22nd Jan 2011, 01:19 -
Possible to search headers of Usenet newsgroup?
By sdsumike619 in forum ComputerReplies: 15Last Post: 14th Sep 2009, 22:42 -
Authored DVD exceeds DVD spec bitrate - advice needed.
By outerspacerace in forum Authoring (DVD)Replies: 27Last Post: 14th Jun 2008, 22:23 -
DVD-Video Audio Spec. (Dolby 2.0) vs. Blu-Ray Disc Audio Spec. (Dolby 2.0)
By Disco Makberto in forum AudioReplies: 5Last Post: 31st May 2008, 14:30
