the dvds i backed up play successfully on my ps2 n on my friends pioneer stand alone dvd player
the problem is i can't get them to play on anything else]
i use DVD Shrink n Nero 5.5 to back them up with
i use 1.02 standards
can anyone tell me how to make my movies play on most machines???
Results 1 to 9 of 9
Use different media for each one !
What media have you tried so far ? You might find you need something with a little wider compatibility. My Sony is a nightmare when it comes to DVD-R compatibility but the following work very well:
Nan-Ya
Ritek G03 & derivatives
Ritek G04 & derivatives
TDK G002 (genuine and some clones)
e-Proformance (prodisc, IIRC)
If I don't go to the edge:
Bulkpaq Turquoise
Choice Media
And I can't use these on ANYTHING !!
Vivastar
And the list goes on. Basically, if you're using mega nasty Jap-Crap media then try something else, but look into the manufacturer NOT the "brand" because most of the media manufacturers make media for other people, so you could end up buying the same discs twice and not knowing about it until you got home ! -
If you are using a later version of Nero (v5.5.10.15 or later, I use 5.5.10.7b with no problems) try 'DVD Video'. The latest one of v5.5 which is v5.5.10.42 should be near perfect in 'DVD Video' mode.
Also garryheather is correct, I have had glitches in the video when I use IMATION DVDs on my player, but No.1 favourite is TDK, oh so sweet. -
Yep .... media is definitely a major factor .... I prefer Ritek myself ... they have always performed 100% for me.
As mentioned above, grab the latest version of Nero 5.5.10.42 and try the Wizard for DVD-Video. The earlier versions of Nero did produce slightly non DVD compliant files, but this has now been sorted out. -
try udf 1.50
some of the earlier dvd video dvd players
didn't recognize udf 1.02
what is your dvd player -
hrm...i thought it was the other way around...Originally Posted by vance43211
some older players didn't recognize 1.50.....only the earlier 1.02 -
you are rightOriginally Posted by poopyhead
but some of the original dvd video dvd player that came out before udf 1.50 had become standardized don't
like say this 5 disc hitachi that i sold to a neighbor for $40.00 because it had that problem. it will play udf 1.50 discs but not udf 1.02 discs
that was why i got rid of it
VHS-C playback issue, playback in B&W and distorted/noisy colour.
By jpoel in forum Newbie / General discussionsReplies: 4Last Post: 11th Aug 2010, 09:36 -
DVD Backup - erroneous playback on dvd player althought perfect on the pc
By RedBolt in forum Authoring (DVD)Replies: 3Last Post: 11th Jun 2010, 23:00 -
DVD to storage drive, best media player for dvd playback- newbie questions
By omkls08 in forum Newbie / General discussionsReplies: 1Last Post: 24th Nov 2009, 10:22 -
Pinnacle 11 - playback issues on DVD - rapid playback problems
By crven in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 09:19 -
DVD+/-RDL Playback on Yamaha DVD-C750, DV-C6770, and DVD-C950
By Big C in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Aug 2007, 08:59
