I recently received my first DVD-Audio and can't seem to get it to play in 5.1 Dolby Digital surround. The album is The Doors LA Woman. I'm using an HK AVR Dolby Digital Home Theater Receiver with optical input from a panasonic DVD player. Sound great in stereo, but in the surround modes I can get it to play in (such as Pro Logic II), the vocals are very quiet and hollow.
Any suggestions?
thanks,
David
does 5.1 work on your DVD-Video discs? if not then you need to setup your DVD player to output dolby digital instead of stereo PCM.
What happens if you press the "audio" button on your DVD remote during playback? does it switch to the surround track or stay in stereo? Can you select 'setup' or 'audio options' from the menu on the Doors disc? -
It didn't occur to me to adjust anything on the DVD player, so I'll investigate that. Yes, the menus for the DVD disc does give me the options to play in stereo or in surround, but the Receiver won't go into Dolby Digital mode no matter what I select on the menus.
Dolby Digital Audio bit depth = 16 bits??? Why?
By Bonie81 in forum AudioReplies: 6Last Post: 12th Jun 2011, 22:44 -
Synchronization Probelm with Dolby Digital EX Audio, Help!!
By caesarhawy in forum Authoring (DVD)Replies: 0Last Post: 23rd May 2009, 09:35 -
Home Theater in a box audio- No Dolby Digital?
By PhoneMatt in forum Newbie / General discussionsReplies: 3Last Post: 28th Dec 2008, 16:34 -
From Dolby Digital AC3 to Dolby Digital Stereo and back
By moviebuff2 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Dec 2007, 20:54 -
How to edit multi audio dvd s ? (dts, dolby digital keeping both)
By live4fun in forum EditingReplies: 10Last Post: 3rd Jul 2007, 05:08
