Hi,
i'm trying to encode a DV file (digitalized analog VHS Material) to Mpeg4 or Mpeg2 (SVCD) .
If trying to convert it to Mpeg 4 , the converting process stops after 10 minutes of the film, if i'm trying to convert it to Mpeg2 the terminal window appears and there are some messages (no error messages) , the last one is : Press [q] to stop encoding .
And immediatley after that i got the prompt of the shell, it seems to be there is no action, i haven't found any Process (via ps....) .
I'm using OS X 2.6 , ffmepg 0.0.7d , and the latest versions of mpeg2enc.txt, mencoder and mplayer.
I also have installed these 3 package files .
Any ideas on what could have cause the problem ??
Thank in advance.
Bernd
orbsGuest
Expert advice needed regarding mpeg2 (ts) to mpeg4 (h264) encoding issue
By janvandenberg in forum Video Streaming DownloadingReplies: 16Last Post: 13th Dec 2011, 18:52 -
dvddecrypter stop recognize dvd in drive, got img burn,it stop recognize
By ninjinturdle in forum Authoring (DVD)Replies: 3Last Post: 21st Jun 2011, 13:30 -
Encoding .DV problems with ffmpeg (e.g. MPEG4 -> DV or VOB -> DV)
By AlphaMonk in forum ffmpegX general discussionReplies: 1Last Post: 23rd Feb 2010, 05:24 -
encoding mpeg4 with ati MMC results in green video
By toomanyblastedbits in forum Capturing and VCRReplies: 1Last Post: 6th Oct 2008, 02:39 -
TmpgEnc 3 - stop it from encoding 544x576 ?
By katykaty in forum Authoring (DVD)Replies: 3Last Post: 10th May 2007, 18:06
