Hi, I've a problem with burning my VCDs with WinonCD. I split a huge file into smaller parts using DVTool0.24. After that, I put together a project in WinonCDs extended VideoCD-Editor.
After adding the small MPG-parts, WinonCD overestimates the size, e.g.
600MB sliced into 6 files @ 100MB
Putting first file in WinonCD works! =100MB
Only(!) putting second file in =200MB
Putting only the sixth file in gives 600MB
Seems that WinonCD reads the former position in
each file, or what?!
So when I putt together all files, I got to 1,2GB
I'm desperate. I've no clue. What am I doing wrong? Is it a matter of splitting or of winonCD. What else software should I use? Don't tell me to use Nero, as I like WinonCDs Editor much for menu creation. (BTW: Nero works)
Please give me an advise, look around here, but did'nt find a solution.
regards Jens
