I have downloaded programmet Divx Fix to correct my AVI files. But the programm doesn't seem to be doing anything at all. The files aren't still working. The program also shows that " NOTE: The error checking is not perfect!" ????
There isnt much options in the pop up menu, i just open the file i want to be fixed and click the "check errors" but no luck until now!
Is there a better program to use instead of DixFix, or is there anything i am missing to do.
Results 1 to 1 of 1
Is there a program like AVI Recomp but for all Files ?
By Simmons in forum Video ConversionReplies: 3Last Post: 5th Jan 2011, 02:17 -
How to fix uneven audio volume in MKV/MP4/AVI files?
By ConverterCrazy in forum RestorationReplies: 5Last Post: 18th Jul 2010, 23:26 -
joining 2 AVI files via VirtualDub or another program
By cfs6254 in forum Newbie / General discussionsReplies: 4Last Post: 4th Feb 2008, 12:15 -
What program gives the best quality results, when converting AVI/DIVX/XVID
By Rockstar452 in forum Authoring (DVD)Replies: 3Last Post: 3rd Dec 2007, 01:19 -
Fix Bad Header/Bugs in an .avi divx file
By krisbee in forum LinuxReplies: 3Last Post: 24th Sep 2007, 07:54
