I was encoding a file and it had 9 minutes left.. i don't want to encode the whole thing again.. is there anyway to resume encoding with TMPGEnc?? please say there is...
Sorry, there is none.
I wish there was too! Maybe they would add that function in the future? Hopefully..
There is, sort of anyways
If you know EXACTLY where the encode stopped, you can use the source range feature on the advanced tab of settings, to restart where it stopped. Then use TmpGencs mpeg tools merge and cut to join the two files together. -
Like the previous poster said.Use the source range to set the start and stop points of the video file,and bingo.
bmiller,ont.canada
problem with tmpgenc author 4 trying to re encode
By kingsley in forum Authoring (Blu-ray)Replies: 1Last Post: 19th May 2012, 17:28 -
Does TMPGEnc re-encode when burning to blu ray?
By daysaf00 in forum Authoring (Blu-ray)Replies: 1Last Post: 17th Mar 2012, 02:12 -
TMPGenc 4.0 Xpress can't encode AVI with 16:9 display
By Sanderverbeke in forum DVD RippingReplies: 2Last Post: 23rd May 2010, 07:21 -
How to encode using TMPGEnc Xpress to 264?
By klas in forum Video ConversionReplies: 1Last Post: 8th Jul 2008, 04:13 -
How to batch encode with TMPGEnc
By BonnieW88 in forum Video ConversionReplies: 8Last Post: 20th Feb 2008, 20:52
