Hi, I use dvdshrink 2.3 to rip the "movie only" vobs to my harddrive. I then use instantcopy to compress them. For some reason when I test the newly compressed movie I get to the second last chapter and then it skips back to chapter 2 and finishes playback with chapter 3. So as in the case with my roadtrip dvd chapters 28 and 29 playback as chapters 2 and 3. I can't understand why, since when I play the dvdshrink rip version there is no problem. I tried using IfoEdit to create new ifo's but that didn't fix the problem. I also copied the ifo's from the dvdshrink rip to the instantcopy video_ts directory and it didn't work either. Is it possible that during the transcoding process that instantcopy after it finished chapter 27 went back and copied the audio and video from chapters 2 and 3 and added it on? Any help with this problem would be greatly appreciated. Thanks,
GaryK.
Hmm...
Check the outputted vobs (on your computer from HD) and see if it plays the same way.
If not, it's probably just that your media is bad (what are you using?).THIS has been an RVL123 production... -
Thanks for your response. When I tested the video, I read it directly off the harddrive so its not the media (haven't burned it yet). I opened the vobs and sure enough, the last vob containing the last 2 chapters is screwed up - it contains the audio and video of chapters 2 and 3. I can't understand it. Why would instantcopy skip the last 2 chapters of the movie and tack on a couple from the start ? My instantcopy version is 7.03.140 with hidden settings editor 1.3.4. I tried it again with a couple other movies : Manhunter and Suicide Kings. Same problems occurred. Any suggestions ?
Problem creating burnt-in subs for other chapters with AutoGK
By Squirrel448 in forum SubtitleReplies: 5Last Post: 3rd Jan 2011, 18:07 -
problem getting chapters with MuxMan
By alivecamel in forum Authoring (DVD)Replies: 4Last Post: 25th Aug 2010, 02:49 -
Problem making chapters with RDR-HX780 Sony HDD recorder
By 1234567 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Feb 2010, 10:56 -
chapters
By natty in forum Newbie / General discussionsReplies: 0Last Post: 23rd Feb 2008, 12:42 -
How do I, add chapters in Nero causing sync problem
By breeze9 in forum Authoring (DVD)Replies: 2Last Post: 22nd Jan 2008, 06:37
