I made a photo album with PictureToTv for a friend and her family. Unluckily she has a DVD player that doesn't support VCDs. My question: what is the simplest way to convert my PicturetoTV photo album to DVD? Thanks all.
Kevin
Simplest way would be to go to Walmart and buy a $59 DVD Player that would play VCD, SVCD, DVD, MP3 etc. Barring that you could hook the output of YOUR DVD Player to your computer's capture card and use Virtualdub to capture your Picture2TV program to an avi file, then author the avi file in something like MyDVD, or Pictureshow2, and then burn to your DVD Burner. The first way might be cheaper though .....
"No freeman shall be debarred the use of arms." - THOMAS JEFFERSON .. 1776
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 19:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Help with VCD to DVD
By bwheeler in forum Newbie / General discussionsReplies: 9Last Post: 28th Jun 2007, 02:25 -
Dvd to Vcd
By tryst1 in forum Video ConversionReplies: 2Last Post: 5th Jun 2007, 01:30 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
