I have a PAL dvd and i was wondering if there is any easy way to convert it to ntsc. I try using ffmpegX, and the video always ends up shorter, b/c its moving faster, and I also want to keep the menu. Thanks , JAT
Hello. I had the same problem. I bought a British show called " Sapphire and Steel" from Australia. It has 6 discs and i've tried every software that supposed to convert it. Holy mackarel!!! It was slowwwwww. I guess it has to go through each frame of the movie. I used a PowerBook 867 G4. So i bought a Philips 726 dvd from Best Buy for 89.00 + tax and just captured it from there plus i had to buy the canopus advc 100 to convert it. So total --it cost me around 350. I don't know if there's any other easy way. I didn't mind spending that money because i was planning to convert my home movies anyway.But i think thats it . Also you can just buy the Philips dvd 726 and you don't have to do anything.
Any one have a easy software solution for converting a PAL DVD to NTSC DVD on a MAC?
thanks
Bernie
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 20:53 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 01:47 -
playing PAL Hi8 tapes in NTSC camcorder output to PAL DVD recorder?
By interlooper in forum Capturing and VCRReplies: 2Last Post: 17th Jan 2009, 14:36 -
PAL Video Cassette Recorder or [Multisystem VCR] for PAL->NTSC playback
By quantass in forum Newbie / General discussionsReplies: 10Last Post: 12th Dec 2008, 13:47 -
convert PAL HDTV 1080i -> PAL DVD 576i
By halsboss in forum Video ConversionReplies: 0Last Post: 20th Sep 2007, 21:13
