Hi all,
I'm just about to splurge on a spindle of 100 TDK 2x but I haven't tested it with my A06/106 Burner. I'm relying on all the positive things that have been said about TDK media. So just before I place the order, is there anyone out there who's had problems with TDK media with the Pioneer A06/106?
Cheers,
feeras
My AO4 burns it to the edge
No coasters so far.
Should work fine for you.THIS has been an RVL123 production... -
Ive had the same luck as the poster above me. 25 pack...1 coaster (user error, not TDK's fault at all) 24 DVD-R's burnt to the brim and played in every player I tested them in. 2 20 packs, I finished one, not one coaster, halfway done on the 2nd pack and sure enough not a coaster. BTW, first pack (25) was made in Japan, last 2 20's, made in Taiwan. Despite the location change, they appear to be of identical quality, great discs.
Oh and a few additions...Im using an AO4/104 but I'd expect a 106 to write these discs just fine. The only media I hear that is kind of iffy with these Pioneer burners are the low-cost discs like Princo, and occasionally Ritek.
My Pioneer DVR-531H-s has developed burning problems ... replace burner?
By FulciLives in forum DVD & Blu-ray RecordersReplies: 86Last Post: 9th Dec 2009, 18:09 -
Need to replace burner in Pioneer 220s
By Brent G. in forum MacReplies: 6Last Post: 12th Nov 2008, 17:33 -
Pioneer DVR-220S and TDK (CMC MAG, AM3) discs incompatible?
By cwerdna in forum DVD & Blu-ray RecordersReplies: 4Last Post: 12th Nov 2008, 16:25 -
Can't burn DVD using TDK burner
By tee jay in forum MacReplies: 7Last Post: 16th Sep 2008, 15:01 -
Just bought a new Pioneer DVR-X152 burner..any advice, comments, PROBLEMS?
By Janey87 in forum DVD & Blu-ray WritersReplies: 1Last Post: 16th May 2008, 23:09
