I have pioneer dv-343. The problem is the dvd-rw (princo) I made
- mpeg1 file converted to mpeg-2 720x480 29.97fps using tmpegenc
- mpeg1 file using ulead dvd movie factory 2
- SVCD 480 x 480 convert to DVD-SVCD 480x480 using svcd2dvdmpeg
all above conversion, when playing back on the pioneer 343 player, the picture is STRECHED, not 1/3 nor 2/3. (4:3 pan and scan choosen on player). Playing it back from computer are all fine.
Is this a pioneer player fix problem? If I use svcd2dvdmpeg+, with pan and scan fix, will it fix my problem?
If not, what other brand of dvd player will do the job?
Any info would be appreciated.
no, i only have 1 dvd player at home. i am using pioneer writer, model 106
does DVD-VCD works on most player without any problem? would it be my player problem? if i decide to buy another player, which one should I choose that will play DVD-VCD and DVD-SVCD?
thanks -
480x480 isn't a compliant DVD resolution. While it may play on some player, it will not on all. I would suggest converting it to either 352X480 or 720X480.
Xvid AC3 file playback problem on Standalone DVD player
By kamol88 in forum Video ConversionReplies: 2Last Post: 21st Mar 2009, 04:38 -
DVD Player Playback Problem
By allrightjon in forum Newbie / General discussionsReplies: 22Last Post: 19th May 2008, 11:12 -
Strange Video Playback Problem on Dvd Player
By dbgt in forum Newbie / General discussionsReplies: 1Last Post: 10th May 2008, 18:30 -
audio playback problem on television dvd player
By nathy85 in forum AudioReplies: 4Last Post: 16th Nov 2007, 17:17 -
Problem with DVD Playback on Windows Media Player.
By Cereal Bawks in forum Newbie / General discussionsReplies: 5Last Post: 29th Jul 2007, 16:11
