Hi,
Found out from some good help from this forum that ac3 is what was missing to let me convert the audio..44100.the problem now is whats been discussed before why when I convert the audio from a DVIX3 , ac3 is the audio out of sync when I run it as a svcd though mtpgenc. I have tried many options just cant seem to get it right, and I know Im nearly there which makes it more frustrating.
I use vitualdub to extract the audio, can you tell me shoulld I use the compression option in this software or should it be set to no compression, either dont seem to have much success the film audio is well out.
Can the wizard effect the end product in mtpgenc, please help as this little prob is doing my nut in..
cheers sted
Closed Thread
Please read the rules before posting. No cross posting.
https://www.videohelp.com/forum/viewtopic.php?t=172946
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 12:23 -
MPEG4-AVC (H264) + AC3 -> Divx + AC3?
By thomas_fogh in forum Video ConversionReplies: 12Last Post: 1st Nov 2008, 21:25 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 20:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 11:24 -
H264 + AC3 + AC3 --> VOB - What is wrong with my command line?
By olik in forum ffmpegX general discussionReplies: 5Last Post: 3rd Feb 2008, 08:06
