  1. I am trying to encode an avi file into MPG with TMPGEnc. I get this error
    Scan line is out of range -224
    What does this mean ?
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    it ussually means a corrupt frame -- fix bad frames in v-dub ..
    or here is another possable fix :
    https://www.videohelp.com/forum/archive/t78884.html
  3. Thank you for your reply ,
    would you be able point out a guide for fixing bad frames with V-dub as you say ?
    Sorry not very experienced as you can see.
  4. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Originally Posted by [TEA
    Towle]would you be able point out a guide for fixing bad frames with V-dub as you say ?
    Try here.
