i have rip a dvd and it is dvd9 and have 2 layers so i was using the dvdshinker tool for shiking it to make it dvd5 and this perticular dvd have no extras it only has MENU AND MOVIE so the dvdshrinker shrink the menu to 81% and movie to 53% and my size is still bigger than 4.7 gb and it won't let me save/convert it to dvd5 formatand since the dvdshinker is new version automaticaly does the shirnking i can't do shinking by my self!! as ratio or pictures.
i have ripped 62 songs dvd and i am willing to get rid of few songs if i have too and make it the 4.7 size dvd5!!
now i want to know that if i want to cut some of the parts from those movie/vob files that i have ripped from dvd how do i do it? what tool should i use?![]()
Remember DVD Shrink 3 is still in BETA stage so you should report these bugs to the author.
@illegalkarma,
are you using DVDshrink v2.3 or v3.0 beta????
v2.3 doesn't always predict the final size very well... i've had errors of 200-300 MB. that's right...even though DVDshrink claims the output will fit on DVD5 (4489 MB), the output filesize was 300 MB bigger....
this is to be expected...since v2.3 makes a prediction by analyzing a small percentage of the frames...so, don't expect too much.
all you need to do is to compress more and try again
otherwise, the latest version 3.0 beta has a deep analyze feature (which takes about 40 min in addition to the actual compressing) that analyzes every single frame. because of this, DVDshrink can predict the final output filesize very, very accurately and you won't have to worry about not fitting on DVD5.
LCD Monitor Screen Size, bigger isn't really bigger?
By Des in forum ComputerReplies: 13Last Post: 27th Dec 2011, 14:13 -
How do I burn a DVD bigger than 4.7 GB?
By Rayroshi in forum Authoring (DVD)Replies: 12Last Post: 29th Nov 2011, 07:02 -
How to put files bigger then 4gb on FAT32 hdd
By WinSpecToR in forum ComputerReplies: 14Last Post: 14th Jun 2010, 06:22 -
bigger DVD-RW's than 8.5gb??
By cedarhill in forum Newbie / General discussionsReplies: 4Last Post: 18th Nov 2008, 14:46 -
How do you make screen size bigger on Philips dvd model DVP642?
By jkristoff in forum DVD RippingReplies: 9Last Post: 23rd Jul 2008, 04:33
