A while back, when i was a complete newbie, i backed up a movie by just stripping the main movies files using SmartRipper. This created a ONE large vob file, for which i created the ifos etc. Tested on PC works fine. I noticed that this doesnt work on the settop player, as its just one big vob file for the whole movie. Ive tried creating new ifos which simply just enable it to play in my PC. My original DVD is now in a very bad state so its impossible for me to rip it again, and extract all vobs individually.
How can i extract this one large vob or, create ifo's which will enable it to play on my player. (all my usual backups work fine, this is just a very old one)
Process the file with an Authoring program and it should make it back into 1 gig files.
Cheers for the advice,but im not sure on how to do this. Please could you give me a pointer to which tools i can use and the steps to take.
Thanks -
open the vob file with IfoEdit (you will need to select all files in the open dialog window to see your vob file) select vob extras tab (at the top of ifoedit main window) tick create new ifos and set the file size (right hand side) to 1 gb set the destination directory and click ok wait until completed .. you will now have several vob files + the required ifo/bup files(select yes if asked to save to bup) close ifoedit and then reopen ifoedit (it is important that you do this) open the VIDEO_TS.ifo file that you created and click get vts sectors (bottom of main window) close ifoedit .... burn your dvd ...... it will play in your standalone as well as your computer
Busipaln,
When you re-author, the authoring tool will automatically chop the huge VOB file into 1GB or smaller pieces. -
thanks for the advice guys, only thing is ive never re-authoured a DVD, If im not wrong i think DVD Shrink re-authors???? am i correct. Any pointer to guides would be appreciated. Thank you
I use Ulead DVD Workshop, but you can use any authoring prog. Just click on the Author How To and any one should do the trick.
Encoding problem. Creates large unopenable file.
By Haole Dave in forum ffmpegX general discussionReplies: 0Last Post: 23rd Jan 2012, 16:30 -
SPLIT A LARGE VOB FILE INTO 1GB CHUNKS AND AUTHOR
By jimmalenko in forum User guidesReplies: 39Last Post: 12th Aug 2011, 09:37 -
Video file created as MPEG but becomes VOB when moved to other computer
By SteveHarris911 in forum Video ConversionReplies: 10Last Post: 29th Apr 2011, 17:45 -
ULead Videostudio - creating a DVD from a single large VOB file..
By djdust in forum Newbie / General discussionsReplies: 2Last Post: 19th Feb 2008, 13:34 -
How to break large vob file into two disks?
By chobo321321 in forum Authoring (DVD)Replies: 1Last Post: 28th Jul 2007, 12:53
