You need a MPEG2 Codec PowerDVD should have installed one. Install it again or double check. WinDVD, powerDVD are the two main programs people use to get/install a MPEG2 codec. There are others. Take a look to the left under play.
Thank you my friend!
Installed MPEG2 Codec and tried on CyberLink PowerDVD XP 4.0, WinDVD Platinum v4.5, Window Media Player. Obtained the mpg file from SVCD MPEGAV folder as per instruction on http://www.dvdrhelp.complay.
All returned fragmented picture - mostly green in color.
At present the following codecs are concurrently installed in my WinXP puter :
AVI codec;
ATI Playback Codecs - vcr2;
Divx MPEG-4 Video codec;
ffdshaw AC3 filters.
Neither have any luck with PowerDVD uninstall/re-install. The players can view other mpeg. -
are you sure that really is a svcd ?All returned fragmented picture - mostly green in color
maybe its a xvid or something else .. -
BJ_M
Now I got it. I burnt the bin file into SVCD and click on the mpg instead of directly viewing from the hard disc.
Thanks for the trouble !
Converting Ripped Blu-Ray VC-1 Codec to MPG or AVI
By MisterZJ in forum Video ConversionReplies: 12Last Post: 24th Aug 2009, 14:12 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 10:41 -
SVCD 704x480 mpg stills with audio?
By jungle5150 in forum Authoring (VCD/SVCD)Replies: 21Last Post: 29th Jul 2008, 17:28 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
best format/codec for compressing an mpg???
By cduval04 in forum Newbie / General discussionsReplies: 1Last Post: 28th Dec 2007, 20:31
