So I just bought 8 Mile, and I would prefer to keep all the special features and stuff in there...
Anyone know what is the best program(s) to use? I rarley compress the whole DVD, if ever, so I am not sure...
Any help would be appreciated!
CX
Results 1 to 9 of 9
I would use Nero Recode, But I'm sure many people would disagree. However I think it's works great.
IMHO Nero is worth about as much as a bag as warm hapster dung. But there are people that use/like it (it's a free country). You asked about the best, well best is a subjective term.
The best is to buy a 2nd copy and don't open itNo lost in quaility spilt to two DVDR discs (IfoEdit can do this as well as other freeware tools, IIRC DVD Fab is still freeware).
If you want to compress it to one DVDR the best quaility results from re-encoding using CCE/TMPGenc but this takes a lot of time and can get complicated (eg. the big3, see guides at doom9.org).
If you want a one step program to transcode everything for you you can go with: Instant Copy, DVD2one, DVDShrink or DVD95Copy. DVDShrink is freeware the rest will cost you. The general feeling is that IC produces the best quaility, but many think that DVD2One produces better quaility.
Truth is it depends on your source (size, level of motion, % of dark scences, etc). -
I use SmartRipper or dvddecryptor to rip the DVD then DVD2one to compress. DVDShrink works good too and its free.
The version I use doesn't have that option, but I would choose Variable Ration.
I'd use DVDXCOPY if you want it to look as good as the original.
DVDShrink or DVVD2ONE for compressing.
Problem backing up Blu-Ray using BD Rebuilder with milOtis method
By TJMac44 in forum Blu-ray RippingReplies: 15Last Post: 7th Mar 2011, 14:43 -
Best Method to Convert for Full Screen Viewing
By Deter in forum Video ConversionReplies: 8Last Post: 23rd Nov 2009, 19:43 -
Best method for backing up TV shows from DVD
By android6011 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Jun 2009, 20:03 -
What is the best method for backing up a DVD to DVD+R DL Media?
By xoADAMox in forum Newbie / General discussionsReplies: 8Last Post: 28th May 2009, 04:36 -
PAL to NTSC DVD [Full Disc] Conversion (hybrid method, very easy)
By LadyLiete in forum User guidesReplies: 28Last Post: 5th Nov 2007, 20:35
