I see posts here stating what speed their DVD-ROM is ripping. How do you do this? I've used DVDInfo for speed testing, but it almost sounds like people are getting real-time speeds while ripping. Is there ripping software that reports real-time ripping speed?
Anyway, I have an older Toshiba SD-M1302 8x DVD-ROM. Based on posts here, I purchased a Lite-On HD166S 16x DVD-ROM from Wal-Mart. Based on the speed test results from DVDInfo, both units max out at ~7.5x. I tested using two different movies (Usual Suspects & We Were Soldiers). Both are operating in Ultra DMA Mode 2. Is this a DVD-ROM problem or is something on my PC holding back the speed, or should I be using different software to test ripping speed?
Mobo: MSI K7T266Pro2-A
AMD Athlon 2000+
MSI GeForce 4 Ti4200 128MB
Mushkin 512MB PC2100
Pioneer A06 DVD+/-R/RW (ext.)
Win XP Home -
SmartRipper and DVD Decrypter show you the transfer rate while they do their thing.
Your PC might be running at less than the optimum, IDE devices run better when there isn't a lot of traffic on the bus (so an IDE based drive will occasionally run better if it's got a channel all to itself). UDMA has a bearing on the results you will see, as will the speed of your hard disks (can they keep up ?), processor speed to some small extent, cleanliness and quality of the disc you are trying to rip... -
I tried one of my kid's DVDs (30 min video). The Lite-On did reach 14x.
I didn't know DVD9 disks could not be ripped at high speed (>8x). I guess I'll stick to my older Toshiba 8x DVD-ROM.Mobo: MSI K7T266Pro2-A
AMD Athlon 2000+
Win XP Home -
The liteon is the fastest there is. Its the fact that on layer switches it slows it down. Thats true on any reader. That 8x will be lucky to achieve 4 or so X on a DVD9.
HideOut -
Speeds tend to go up during the rip and you can rip DVD5 discs faster than DVD9 discs. I've ripped some DVD5 discs at 15.5x! Took <3min total time
For DVD9 discs I get 6-8x. Liteon all the way (waiting for their dual format burner, not the sony OEM they are selling now)
Ripping speed for dvd-r
By vcd4me in forum DVD RippingReplies: 10Last Post: 22nd Apr 2011, 05:45 -
DVD Fab v/s AnyDVD Ripping Speed
By wulf109 in forum Blu-ray RippingReplies: 0Last Post: 25th Mar 2010, 13:04 -
Question about ripping when internet speed is too slow
By jimdagys in forum Video Streaming DownloadingReplies: 1Last Post: 11th Sep 2009, 02:49 -
any new drives better than Lite-On for ripping?
By spiffy in forum DVD & Blu-ray WritersReplies: 6Last Post: 30th Aug 2007, 02:54 -
Anyone have Lite DVD Recorder On DD-A100GX ? ? ? ? ?
By HolyGeez in forum DVD & Blu-ray RecordersReplies: 8Last Post: 30th May 2007, 08:58
