Im using dvd decrypter on file mode and processing the files through Instant copy.
Each of the films comes up (when copied and inserted into a multireional player) Incorrect region? The orignals work fine?
Any ideas?
Tried IfoEdit and it didnt work, wont even play on my DVDROM drive which is multi regioned
I have just re-ripped them to the HDD and used Elecard MGEG2 Player to play the Video_ts.IFO, comes up the same, not for this region? Maybe a ripping problem, should I try it in ISO mode, but I can compress them in this mode after can i?
I have the Region 1 set Has ANYONE backed up these discs. Even if rip them and play VIDEO_TS before encoding, it still comes up with the error, ive tried to infoedit region free at this stage and still wont work.
I have even removed RCE protection, and set to region 2 (my region) and it still wont work!
Maybe the region coding is referenced in more than one of the IFO / VOB chains.
I found the R1 version of The Transporter has TWO region coding checks, and I missed one of them because I use all region hardware.
You can load each into say IFOedit, remove the region coding and then just resave that edited file, then put it onto a blank as usual. -
I have put each and every ifo into IFOedit and even dvddecrytper and still it wont work.Originally Posted by garryheather
MKV DvdRip Xvid Downloads Play on WMP but wont play on my PVR
By dashas in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2011, 05:15 -
Restore a DVD+R that wont play
By ProfHiggins in forum MediaReplies: 10Last Post: 14th Dec 2009, 22:49 -
JVC Wont Play New DVD's!
By Raxxor in forum Newbie / General discussionsReplies: 2Last Post: 29th Dec 2008, 13:02 -
LG DVB-T wont play DVD's
By scdom in forum DVD & Blu-ray PlayersReplies: 1Last Post: 1st Oct 2008, 07:20 -
*for all who use nero,and dvd wont play in your stand-alone*
By headstate in forum Authoring (DVD)Replies: 182Last Post: 24th Jul 2007, 02:00
