  1. I've noticed that the best mpetg2 real time capturers are like the advc-100, which doesn't have a direct analog input place.
    so like.. what do u connect..
    the analogue wire to the vcr, then vcr to the advc-100, and advc-100 to pc?
    and also, is there a device that's good or better than the advc (below 200 dollars) which has a direct analog input so like..
    i can connect analog wire to usb device, and then usb device into comp.
    do u guys think usb 2.0 hardware can beat the pci's?
    or should i just go for a pci hardware than usb external one?
    thx
  2. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    http://www.canopus.us/US/products/advc-100/pt_advc-100.asp
    sure looks to me like it has analog connections....
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
  3. sorry, i meant analog as in a coaxil cable thing.
    that circle which a thick wire in a the middle, which u usually hook up to a tv.
  4. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    for around $15-$20 you can get an RF Modulator, it converts coax to component outputs.
    most any electronics retailer should have them.
    - housepig
    Housepig Records
    out now:
  5. thx for the reply.
    so now, my options are the
    advc-100
    or the
    Plextor ConvertX (which i haven't seen any comments on the captuer cards list)
    can anyoen suggest which one to use?
    i liked the plextor because of the mpeg4 option, but advc-100 seems to have great comments. PLanning on capturing TV shows at mpeg2, and hoping to get a hardware that doesn't kill my sistem
    athlon xp 1800+
    386mb ram
    ga-7vtxh+ mobo
    40 gig seagate
    100 gig wd
    120 gig wd
    geforce 2 mx
    if anyone recommends another product from another company taht can capture from ntsc 720x480 (minimum) and REAL TIME hardware MPEG-2 capture, PLEASE RECOMMEND ME. (going for usb 2.0 product)
    thanks!
  6. Did you ever find anything more out about this -- I just found this Plextor -- first I heard of it. I've heard ton on Canopus and all good -- was wondering how this other compared -- every any news --- how's your system do for dvd authoring? I'm wanting to try and build my own so trying to evaluate what to get.
    justin
