Hi, I need to make a backup of my heavily watched Led Zeppelin dvd, but the thing is 8.2 gigs on the first disc and I think about the same for the second...My question is this: It has LPCM stereo for sound and it takes up a gig on its own...there is also DD 5.1 and DTS 5.1 on the disc...what is the best sound? Is LPCM THAT good to need to take up a whole gig? Has anyone backed up this set?
Here is what I found on another site.
"AC3 is just a compressed version of LCPM, the un compressed stereo equivalent."
Therefore I would say that LCPM is an uncompressed AUDIO streem. So depends, I'm sure you've listend to the other streems. You decide if it's worth keeping.
I'm not a big fan of listening to music in DTS, so I would probably only keep the LCPM and toss the rest. -
Try burning to an RW and try it out.
Swift Kick In The Butt $1.00
"Everybody I know needs what I'm selling!" - Calvin -
LPCM is uncompressed and therefore high quality, I would therefore suggest you keep the LPCM. It will only be two channels, but will have CD quality sound
Burning right now with the lpcm and the other audio's removed...I will also burn one with all 3 audio streams enabled and then one without the lpcm and the dd and dts. all to rw of course
ok: used DVD Shrink and re-authored dvd to make a movie only. added 2 audio streams.(lpcm and dd 5.1) Looks and sounds GREAT. did the same to disc 2. Now I have one more query: I want the extra's from both discs on another dvd-r, but I cant seem to figure out how to get them together onto the dvdr!! what tools should I use. Normally I just decrypt with dvddecryptor then burn with convert and burn with whatever proggy i feel like using at the moment. For this dvd set, I used dvd shrink then burned with copytodvd.
Some help needed with multiAVCHD
By VOYAGER2009 in forum Authoring (DVD)Replies: 6Last Post: 20th Jul 2011, 11:19 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 12:27 -
some help with ripbot needed
By davebarnes2009 in forum Blu-ray RippingReplies: 6Last Post: 12th Jul 2009, 15:07 -
Help with PC to HDTV Needed
By denzlite in forum DVB / IPTVReplies: 12Last Post: 13th Jan 2009, 16:34 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
