I havent been at this for long and so far I'm not having much luck with my DVD-R's.
My problem is that when i playback my DVD-R's, they seem okay for about the first 1 1/2 hours and then they start pixilating and freezing.
Any ideas???
what brand discs are you using? what DVD player are you attempting to play these in? Also what are you using to author and burn?
Sorry a few details.....
I've got a Tomson DTH210 dvd player, Teac DV50E dvd writer and been using Datawrite reds (X4).
I know that in the Dvd players list on here it show that my DVD player doesnt play dvd-r, but it seems to up to the 1 1/2 hour point.
I've tried using DVD Shrink to make a "smaller dvd" to eliminate the chance of the edge of disc problem, but that hasnt worked either. -
test these discs on another DVD player if you can. I dont want to tell you your media is the problem when it very well might just be your DVD player not being very compatible with burnt media.
Just been having another look at the DVD players list and some people think that it has a problem playing the end of princo discs.
Now i just need to find a media that works. -
Originally Posted by scott488
It isn't very pratical to limit yourself to that size but you might want to try it once on the media you have to see if it solves your problem. If it does then you know that it probably is the media and then you can go buy better/different media. If you keep your total file size below 3900MB and you still have playback problems then it very well might not be a media problem.
Originally Posted by scott488Swift Kick In The Butt $1.00
"Everybody I know needs what I'm selling!" - Calvin -
looking here: https://www.videohelp.com/dvdplayers.php?DVDname=Tomson+DTH210&Search=Search
it states your dvd player is compatible with "Few DVD-R"..... however, you should read over the user comments on your particular player and see which media works for them....
otherwise, you can try getting another DVD player (even those cheapo ones) that's more flexible in DVD-R.
Playback problems
By erica12 in forum Newbie / General discussionsReplies: 7Last Post: 16th Feb 2012, 19:33 -
Pinnacle 11 - playback issues on DVD - rapid playback problems
By crven in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 09:19 -
Playback problems in Premiere
By JustinBaker in forum EditingReplies: 4Last Post: 7th Nov 2007, 10:41 -
Playback problems
By Dick Stilton in forum Newbie / General discussionsReplies: 4Last Post: 26th Aug 2007, 07:21 -
Xvid playback problems
By drwho in forum Software PlayingReplies: 7Last Post: 13th May 2007, 21:14
