Hey Guys,
Having a quite a few problems delaying a 5.1 DD AC3 from 25fps to 23.967fps. When I use BeSweet and go right from AC3 to AC3 but with the preset of 25fps to 23.967fps there is no diference from the original. I tried using AC3 Machine to do the same thing, and it worked but the final product has minor popping sounds in the background. So I tried the method of going from AC3 to WAV (5.1 Wave) in BeSweet then from WAV to AC3 but with the preset of 25fps to 23.967fps, the problem I encoundered there is that BeSweet would not transcode the WAV file, just opened the command prompt window and immediatley closed it. If anyone can point out what im doing wrong or what WAV format to convert to, or another method which will get the job done, replies would be appreciated,
Thanks![]()
Look at this thread:
https://www.videohelp.com/forum/viewtopic.php?t=172769
Wait, I think my problem was I was going from AC3 to payload, instead of AC3 to AC3, i'll try it out, thanks
Originally Posted by CyberDude101
You are taking a PAL DVD AC-3 audio file and converting it with the frame-rate change option in BeSweet to a new NTSC DVD AC-3 audio file.
So why are you talking about CBR and VBR ???
hehe, in the Command prompt when it's encoding it says Bitrate Method: CBR, I thought you could change that to VBR, but I realized that you couldn't, disregard
. Everything works great and im not getting the clicking noise in the background with the newer beta of BeSweet,
25fps-source Ac3 to 23.976fps
By Lastman369 in forum AudioReplies: 47Last Post: 26th Sep 2014, 02:19 -
2 Channel AC3 25fps to 24fps eac3to problem
By Pegbeard in forum AudioReplies: 23Last Post: 13th Apr 2010, 19:41 -
25fps to 23.976fps
By Charmer in forum AudioReplies: 19Last Post: 8th Aug 2009, 10:41 -
Avi:from 29.97 to 25fps. How?
By Instant Martian in forum Video ConversionReplies: 17Last Post: 8th Jul 2009, 12:26 -
25fps to 29.97 or whatever
By BsMx in forum Authoring (Blu-ray)Replies: 3Last Post: 1st Jul 2009, 15:34
