All of a sudden I keep getting the message "Drive is in use by another application" whenever I try to burn anything. I'm not using any other application, and I've tried uninstalling and reinstalling Nero 6, but I'm still getting the same message. By the way, I'm using a Sony DVD writer.
Can anyone help?
Results 1 to 9 of 9
I'm no expert, but try turning off the "imapi.exe" in the task manager. This should free up your drive, so you can burn. Later on, you may want to go into your services and turn the imapi.exe off completely.
Sometimes music players like real one or musicmatch have access to imapi.exe. Try closing these. I get that problem all the time and I do that it and it always rectifies the problem.
Thanks. I'll try that - I think the proper way should be to disable CD Burning support for the drive in XP. btw This is a Firewire DVD-R drive so IMAPI shouldn't(?) be interfering with it.Originally Posted by jester1x
For the time being I've solved the problem by uninstalling 6 and going back to 5 which works perfectly. I have to say that it's left me feeling VERY unimpressed by Nero 6. It's all very well having a program that looks nice and has lots of flashy buttons and icons - but it has to actually WORK! -
Thanks, but neither are running. First thing I checked. Reboot no help either.Originally Posted by hardcoreruss
Thanks, but I'm not running InCD.Originally Posted by cbsmooney
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 20:49 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 20:23 -
Can I install both Nero 8 & Nero 6 on same machine?
By OzarkBaby in forum Newbie / General discussionsReplies: 8Last Post: 3rd Jan 2008, 22:09 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 12:10 -
Nero Recode/Nero Digital users...
By siratfus in forum Video ConversionReplies: 4Last Post: 31st May 2007, 06:06
