I am new to IfoEdit and DVD backups and I would like some clariciations about this program. I am trying to use this program to remove some unneeded trailers in the finished DVD.
IFOEDIT can edit IFO files, create IFO files, stream processing for DVDs, DVD image and burning capabilities included.
So does IFOEDIT remove the actual trailers or does it make the trailers inaccessible from the DVD menu?
If the trailers are still there and I am compressing the original DVD to fit on a 4.7 then that means that the trailers are compressed as well? Is it possible to completely remove it?
IfoEdit does a lot of things there are some good guides:
To the left
http://www.doom9.org
http://mpucoder.kewlhair.com/derrow/
But to answer your question, it removes the titles. So yes the size of teh VIDEO_TS folder generated will be smaller.
I need IFOedit for Mac
By bryceguy in forum MacReplies: 7Last Post: 14th Dec 2011, 12:45 -
Ifoedit, vobs have to be not less than a 1gb?
By Remyisme in forum Newbie / General discussionsReplies: 4Last Post: 25th Oct 2008, 06:12 -
ifoedit question
By J. Baker in forum Newbie / General discussionsReplies: 3Last Post: 17th Sep 2007, 04:10 -
IFOedit question...
By Djard in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2007, 01:42 -
adding CC with ifoedit
By loster in forum Authoring (DVD)Replies: 0Last Post: 9th May 2007, 20:15
