  1. i recently just downloaded this new movie. It was in bin/cue format, however when i go to burn it using a 700mb/80 min disc it will not let me. the bin file is 819 mb and i know this is over the 700mb limit. If i extract the mpeg file from the bin/cue it will let me burn it and it is only 79 min. but will not play back in my dvdplayer. I tried joining the two files so i could cut them and make 3 discs but everytime i try to load it in TMPGEnc i get an error message (also i can not seek while the movie is playing - gives me an inncorrect parameter error). What can i do to burn this movie so that it will play back in my dvdplayer?
    You are in breach of the forum rules and are being issued with a formal warning.
    / Moderator vitualis
  2. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    i recently just downloaded the new tomb raider movie.
    here's a simple answer:
    Do NOT give warez.
    Do NOT link to warez .
    Do NOT ask for warez.
    Do NOT provide information how to obtain warez.
    Do NOT advocate warez.
    Warez includes pirate/bootleg movies.
    do not ask for help with downloaded bootleg movies. You won't get it, and you will get warned and/or banned from the site.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
  3. sorry i edited the original post
  4. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    too late.
    - housepig
    Housepig Records
    out now:
  5. Originally Posted by jba6511
    the cue/bin files do not necessarily reflec the actual .mpg filesizes...
    btw, (S)VCD mode 2 burning allows you to fit 800 MB on 80-min CD-R...
    try burning the bin/cue w/o extracting the .mpg file first...
    have you tried Fireburner?? www.fireburner.com
