Results 1 to 9 of 9
  1. My JVC DVD player(XV-521) can't play recorded DVD discs, Maxell-DVDR's recorded with a Pioneer DVDR-A05.
    I think this is very strange because the listing on https://www.videohelp.com/dvdplayers.php?DVDname=jvc+dvd&Search=Search
    tells something different. It should be possible!?
    Anyone any experiences wit this JVC player problem?
  2. which proggie are you using to burn the DVDs???
    if you're using Nero, make sure you burn as UDF 1.02:
    https://www.videohelp.com/forum/viewtopic.php?t=127624
  3. Hi poopyhead,
    Yes indeed, Nero.
    Where can I find this UDF-seting?? I can't find it.
    TIA.
  4. gvds,
    I just discovered that my JVC XV-SA75GD won't play TMPGEnc encoded CBR without freezing up at simple blank screens. It will play if VBR is used instead. Related problem?
  5. @gvds,
    are you using Nero Express or Nero burning rom??
  6. No, I'm not using Nero (at least not knowingly). My problem was specific only to TMPGEnc CBR encoding. Wether I burned with their TMPGEnc DVD Author burner (not sure of the underlying engine) or if I used the Veritas Record Now software that came with my Sony VAIO - I had the problem. But, my JVC player worked fine with if encoded with a VBR or if encoded with Sony's Click To DVD. FYI, more info on my problem is here: https://www.videohelp.com/forum/viewtopic.php?t=172732
    Good luck,
    Jay
  7. Poopyhead,
    I am using Nero (buring Rom).
    My problem is not solved yet.
  8. gvds,
    I don't have Nero, so I can't help you there. However, if it can be set in Nero, I would imagine you could find how to by searching these forums or others with Google.
    If I were you, I would try another burner to rule out if the Nero software is the problem. TMPGEnc DVD Author has a burner and is free to try for 30 days.
    So, I assume you are not using TMPGEnc to encode your MPEG with CBR? That was the only problem I found with my JVC.
    Jay
  9. - Jay,
    Thanks for your information.
    - Poopyhead,
    Where are you? What do you think ??
