I do a weekly cable TV show called THE HAPPINESS SHOW (yeah, all about the art and science of it), and I was wondering if my capture settings should be different if I intend to make copies of my original VHS tapes (so I can cablecast to other nearby communities).
I've been able to capture 720x480 using WinTV-GO, Btwincap, huffy, and TMPEGnc on a 500 mHZ pIII and plan to make DVD's and then make VHS copies from the DVD. These VHS tapes would then be cablecast.
Should I be using different settings, and since I haven't worked with bit rate, should I be using a different one than the default?
Results 1 to 1 of 1
Are my capture settings ok ?
By smartel in forum Capturing and VCRReplies: 107Last Post: 29th Mar 2012, 10:13 -
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 11:42 -
Capture Settings for Divix
By Nosey249 in forum Capturing and VCRReplies: 2Last Post: 13th Feb 2010, 17:45 -
If VirtualDub capture, which one and what settings?
By tluxon in forum Capturing and VCRReplies: 3Last Post: 20th Jan 2009, 20:05 -
Assistance with Capture settings
By kiwiusa in forum RestorationReplies: 0Last Post: 14th Jan 2008, 18:41
