Well the subject kinda says it all. Whenever i try it says NO!!! im using TMPGEnc DVD Author. Must be some way. By the way im putting multiple SVCD's onto one DVD
It is not possible in general. You may be able to hack it in some way or another, but it probably wouldn't work on most DVD players
TMPGEnc DVD Author will let you as long as the PAL and the NTSC videos are on different tracks.
Keep in mind you must have a DVD player that will play both formats or your not going to have a very usefull DVD.
BarneyOk Ok Ok, I know I'm not as smart as all of you. But look how much smarter I make you look! -
I think commercially they always use a two sided disc for that
SO you could burn a dual side as well -
If you can view NTSC material then it is probably best to convert the PAL clips to NTSC so that the entire DVD is NTSC.
You can convert NTSC to PAL but in my experience PAL converts better to NTSC than vice versa.
Then again my experience is mostly with doing PAL to NTSC since I live in the USA (we use NTSC) but although it is POSSIBLE to convert NTSC to PAL I think you are still better off doing PAL to NTSC unless you only have a PAL TV but if your TV can handle a true NTSC signal then that is the best way to go.
There are a few guides and many usefull posts on this website for doing such PAL to NTSC conversions.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 21:53 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 12:30
