  1. i have a very small moving image on my desktop in DivX format, it is only about 50kb. I was wondering, would it be possible to convert this file into a .gif so that i can have it is an avatar?
    or is there any other way i can do this.
    thanks
  2. HyperCam maybe? Then maybe take it into a animation program like PaintShop Pro's Animation Shop?
    http://www.hyperionics.com/hc/index.asp
  3. so can animation shop actually allow me to save the short clip as a gif?
    May 2003
    Pal Realm
    Not without saving each frame of the divx animation first.
    Then pull each into PaintShop Pro Animation Shop or similar prog and make your ani gif.
