Hi all,
When I first started making backups I used DVDXCOPY, of course that created 2 disks for most movies I backed up.
Now along comes DVD Copy Express and the same movies would now fit on one DVD.
Is it possible to use the 2 backup DVD disks, running them through DVD decrypter to make one DVD using DVDXCOPY EXPRESS? I know DVDXCOPY EXPRESS won't let you recopy a dub.
Or should I just shove in the original DVD and use Copy Express to make a one disk backup?
Thanks to all who reply, I don't know if I will actually DO this, I 'd just like to know if anyone else has tried it.
J T![]()
You don't have to have those mentioned B4 proggies, try DVDShrink v.2.3, it's free and works just as well if not better.
Why would you even want to combine the two discs, when your results will be better -- and a great deal easier to achieve -- using the original DVD to backup to one disc?
it obvious....get (borrow???) the original again and use DVDXCopy XPRESS to compress back up into one DVD.
Regards -
quote="Triple_Helix"]Why would you even want to combine the two discs, when your results will be better -- and a great deal easier to achieve -- using the original DVD to backup to one disc?[/quote]
That's what I thought! Just wanted to ask you gurus to see if someone had a 'better' idea.
J T
Can't play homemade DVD copies on player
By poz3614 in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2010, 07:26 -
Region Free DVD-R Copies
By Live2WinForever in forum DVD RippingReplies: 7Last Post: 22nd Mar 2010, 15:18 -
LG LHB953 not playing burned copies of my DVD's
By SMaldo in forum DVD RippingReplies: 8Last Post: 3rd Jan 2010, 22:43 -
Organising DVD copies on external HD?
By terrypin in forum Newbie / General discussionsReplies: 5Last Post: 1st Feb 2009, 09:43 -
DVD copies
By JimboS in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2007, 23:33
